Acer Aspire 5315 Notebook Logo
Anonymous Posted on Dec 20, 2008
ACER ASPIRE WON'T TURN ON AND RED LIGHT FLASHING
My sister's ACER ASPIRE 5315 won't turn on and red light's flashing even without battery anf power supply! Please help.
  • 1 more comment
  • Anonymous Dec 20, 2008
    Yes, the lights still flashing even leaving over night without battery and power... it just wont turn on and she only uses the pc for brownsing the net and messenger...
  • Anonymous Dec 23, 2008
    Dear crayzeetrayn,
    thank you for your help... my sister left her laptop without power for more than 24h and suddenly the light turned off and she could turn the lap on again... it is working as normal... we hope that won't happen again... thanks... and have a happy xmas and happy 2009....
  • Anonymous May 11, 2010
    So you still have a flashing light when it is unplugged and the battery removed?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4743
Points
Acer aspire 5315 wont turn on, but the battery led lights up when the ac adaptor is connected..pls help.
paul
Level 2:
New Friend:
  • Expert 88 Answers
  • Posted on Jul 12, 2012
paul
Expert
Level 2:
New Friend:
Answers
88
Questions
Helped
20863
Points
189
THIS SOLUTION CAME FROM CHIP way 2 go chip
This is a sample of what you can try to do to diagnose a non-starting computer, If these don't work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Anonymous
Level 1:
New Friend:
  • Posted on Jul 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4743
Points
Mines doing the same thing. The fans will start for 5 seconds and the green light will come on then after that 5 seconds it's all gone again.
Mano Faction
Level 1:
New Friend:
  • Posted on Oct 23, 2015
Mano Faction
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4743
Points
Laptop Acer 5315
1.Save work and shutdown laptop
2.Restart the laptop (..up to bios mode is safe enough)
3.Carefully turn over laptop to view battery bay area as it starts up
4.Carefully eject battery (support it) to shut down laptop draining excess charge
5.Replace battery and startup laptop
Anonymous
Level 3:
  • Master 837 Answers
  • Posted on Dec 20, 2008
Anonymous
Master
Level 3:
Answers
837
Questions
Helped
339235
Points
2470
That is a motherboard problem .. The cmos battery is doing that ...
Testimonial: "thanks for your help!!"
1helpful
Acer aspire 4830t-6841 power button blinks 5 times won’t turn on. Happened during latest windows 10 update.
Buy a new powerbrick, it is probably the battery not charging.
If i let my acer run without powerbrick and its battery is empty, i get 5 flashing lights.
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
2008 Lexus ES350 won't start after multiple times
You will need the dealer to look at his, diagnosis of this problem takes special equipment and skills.
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Compac d-530 won't start red light under power button flashing
Take out the battery and only hook up the AC Adapter. Try turning on your laptop and if you still only get a flashing power button then try another AC Adapter. If the same thing happens then that means the motherboard is bad and would need to be replaced.
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Acer aspire 1710 msi laptop makes popping sound when turned on won't start
Popping sounds are bad. Usually shorting electrical somewhere. Is the light on the power brick green? flashing? Red?
It's either a bad power brick or a bad connection in the laptop. You can buy a power brick fairly cheap, but if its out of warranty and the problem is not in the brick its probably not worth it to fix.
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
