Olympus Camedia C-4040 Zoom Digital Camera Logo
Posted on Aug 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Find manual for c4040 olympus
Card error keeps appearing
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Olympus Master 102,366 Answers
  • Posted on Aug 17, 2012
Olympus Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444638
Points
622693
You may order printed manuals and/or download PDF manuals from here.
Anonymous
Level 2:
  • Expert 114 Answers
  • Posted on Sep 07, 2012
Anonymous
Expert
Level 2:
Answers
114
Questions
0
Helped
29430
Points
113
You should clean the card contacts and the camera contacts, use some kitchen paper with alcool. Good Luck
1 Related Answer
Anonymous
  • 919 Answers
  • Posted on May 05, 2009
SOURCE: error code olympus c4040 zoom
At this point it sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card and it can be used again. Make sure you download all images prior to formatting as once the card is cleared all data is lost.
My olympus fe-130 keeps saying card error. I was taking photo's & then that appeared on the screen. It won't allow me to retrieve my photo's. The camera works fine when the card is out.
Most likely ur card is corrupt. take the card out and there should be tiny slider on the side of the card with arrow showing in one direction. ur card , slide it from where it is to the other side and see if u can retrieve ur photos or make it to work again. even if it works again , take ur photos out and format the card before u use it again.
Goodluck.
tip
My old Olympus C4040 is also having major battery issues (going on 5 years of...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
1helpful
Got new olympus memory card, keeps saying card error
Is the memory card the correct capacity? Is it too "big"? ie is it say a 8 gig and maybe your camera only supports 4 gig? I had that problem with my camera-I had bought a memory card which was too high in capacity for it. Check your user manual for the cards and capacity you can use.
1helpful
Error code olympus c4040 zoom
2answers
Picture error
I would recheck all of my settings on the camera. Go to the menu and check everything one by one. Your card may be damaged also. Do you have another card to try? Do you have your manual? If not you can to to www.olympus.com to download a new manual specifically for your camera and it may address this issue. Good luck.
2gb type M card in c-150 card error keeps appearing
The problem is that the largest xD card that your camera can support is a 256mb xD card as long as there is no letter M or H in from t of the 256mb. The 1gb or 2gb cards are not compatible.
9helpful
5answers
Clean or format card error on Olympus XD card
my camara showing error message that clean card or format card,
i have some important photo in memory card so i can,t format the memory card.
while i am connecting with USB cable it,s showing syntex error
help me to retive the thw data..
txs...............
Keeps coming up card error
http://www.inertramblings.com/2004/12/14/olympus-smartmedia-card-error-repairingrecovering-corrupted-cards/
Card errro
Sometimes the card can get a little bit of dirt on it which has caused this error message to appear on my camera.  Just take the card out and carefully wipe the metal contacts at the bottom with mentholated sprits or another cleaner.  This did the trick for me.
It could be a card problem in which case I would see if the same message comes up when a different card is placed in.
hope this helps
Xd card
According to the Olympus website the olympus c350 series camera will only take up to 512 MB xd cards.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
