no year?
never drive, part time 4wd on pavement, unless said pavement
is ice or snow covered.
only AWD allows pavement (tires direct upon) driviing.
part time 4wd is for offroad , off pavement driving,
this is because 4wd has no center differential.
http://en.wikipedia.org/wiki/Four-wheel_driveand with out such, winds up the drive line fast. and breaks it.
wiki states (no year stated by you)
Part-time
four-wheel drive was standard on all models. to 1991
then came
ActivTrak 4WD
cept
4H (high-range
full time four-wheel drive), 4HLc (high-range four-wheel
drive with
locked center differential) and 4LLc (low-range four-wheel
drive with
so do not use LOCKED on pavement. on active track. only 4H
the wiki states the Super-select is retained 2006 to present.
Super-Select 4WD II
read the glove box manual under 4wd
I also have a 98 Explorer, stuck in 4 wh low. Have tried in out of Neutral etc. Help!
I have a 99 explorer and on tue. we had some ice and i put it in 4X4 and it wont come out. Light goes off like it is but i can tell it its still locked when i turn the corners. I Have seen something about pulling the motor down where is this motor at? I am not the best with fixing cars so i dont want to mess anything up worse by me or driving it too long.
Have you been stopping the car and putting it in nuetral before going into and out of 4 low?
