My hp desktop is blinking red and won't turn on and the fan isn't spinning
SOURCE: blinking red lights on startup
If you look up the HP diagnostic LED code on the xw8200, if the red diagnostic LED is blinking 4 times signifies a bad power supply.
SOURCE: HP PAVILION SLIMLINE S3300N MY COMPUTER IS RUNNING
the fans should work since start for a while ...check the power supply if it has any connection to it or if it is connected from the motherboard...is a thing you should concern before you kill you motherboard or even worse the processor...
SOURCE: When I try and start
Hello, would love to help. When last did you boot / shutdown successfully and what were you working on?
SOURCE: suddenly my hp pavilion a1217n
are you referring to the light on the back? if so the power supply has most likely failed, mother board can also cause this issue.
also it blinks multiple times like 7 - 11 times
