Write your answer...
the red light turns on as the sound is cut off to protect the speakers. The red light is indicated with the 'prot' or 'protection' inscription. This means there may be too much sound quite more than the speakers can handle. The amp reacts to that by turning the sound off to prevent or 'protect' the speakers from damage. Try to reduce the sound input to the amp such that it will not cause the turn off. Also be sure the sound output is balanced on either side of the speakers.
hope u find this useful to ur problem
Here is your guide:
http://www.fixya.com/support/t13907270-sony_str_de925_stuck_in_protect_mode
Note : output transistors are embedded inside the Hybrid IC
on some models.
