Hi mariervin
linksys wrt54gs2 v1 wireless router drivers can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
You do not need s driver........... Router setup If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
SOURCE: Linksys Wireless G Router (WRT54G2 V1)
Go to linksys.com. Go to support. Type in your router model number. The software will appear on the screen for you to download.
SOURCE: l have lost internet connection with linksys
Stop using the setup disk. It does not work. Connect to your router via a web browser to 192.168.1.1. Username blank, input your password and configure the router as normal.
SOURCE: i need installation software for a linksys WRT54G2
router do not normally need installation software..
you can access their admin software by putting in the ip address into your browser...
if you are running xp go to start > run and type in "cmd"..
when you get the black DOS screen, type in "ipconfig" and look at the results for the ip address of your "Default Gateway"..
go back and type this into your web browser to access the router...
for linksys the default password is admin, leave the username blank
SOURCE: I lost the disk for the Linksys WRT54GS2
You can download the manual and driver at
http://www.linksysbycisco.com/US/en/support/WRT54GS2
Please rate this solution. Thanks.
