Frigidaire FEF366 Electric Kitchen Range Logo
Posted on May 19, 2017
Frigidaire FEF366DCC range, oven elements won't heat. after using self cleaning function, oven elements quit working. Replaced lamp socket & temperature probe (both defective). Now when you set the temperature, the electronic control panel "clicks" like the range is pre-heating but nothing happens. I tested the lower element with my V-O-M & it tested good. Help, I don't want to order the control module (which seems to be operating properly) unless that absolutely is the problem. Thanks
5 Related Answers
Anonymous
  • 40 Answers
  • Posted on Nov 21, 2007
SOURCE: Frigidaire lower element not working
Does the element have continuity??Did you do an amp reading with the element connected?? Do you have voltage at the element terminals??If you have voltage at the element and you don't read amps when unit is on then it's the element.If it's the coil?The board should be replaced.Local appliance store may have it or can order it.
Anonymous
  • 482 Answers
  • Posted on Dec 18, 2007
SOURCE: no heat from the baking element in the oven
I beleave you are right.
Anonymous
  • 1314 Answers
  • Posted on Mar 31, 2008
SOURCE: Frigidaire oven heating elements **** the bed
open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
BNewberry
Bill Newberry
  • 93 Answers
  • Posted on May 23, 2008
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
daveyates
  • 112 Answers
  • Posted on Dec 28, 2008
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Oven won't heat up
Hello Michele Smith - If neither elements do not heat but the top of the unit works, then they can possibly be faulty elements or connection. However, if you are experiencing other performance difficulties, then you may have a bad control board that needs to be replaced. Consult a professional for an accurate diagnosis.
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Oven will not heat up.
If the oven won't heat, did you check both the bake and broil element? If both are not working correctly you are going to have a control board issue most likely. If only one works, then the other should just have to be replaced.
My grandparents oven caught on fire and fried the heating element for the oven. They replaced the heating element and the oven still will not work. They used a tester and they have power going to the...
We selected this oven element based on the shape shown and the dimensions given in its .com description. It works perfectly. The oven is a built in so, as you can imagine, I was not anxious to replace it. This element was not advertised as a self cleaning oven element, but it did self clean our oven as well as the original element did. My wife and I are very pleased with this purchase.
7helpful
3answers
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
2helpful
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
1helpful
Broiler quit
Have you checked the broil element resistance? Unplug the range and remove the back cover. Remove the wires from the broiler element and place a meter across the element posts. See if the element reads close to a short (It should read very low resistance if good). If the element reads infinite (open), you will have to replace the broil element. If the readings are normal, you may have a bad Electronic Range Control (ERC) board. The board controls the bake and broil features of the oven through two separate circuits. Usually a relay on the board goes bad. Since the ERC is considered "non-serviceable", replacement components can be hard to find. For this reason, the entire assembly is usually replaced. The ERC runs around $100 for your range, while the broil element can run anywhere from $35 to $60. Now...as far as your self-cleaning function is concerned - most electric ranges use BOTH elements to super heat the oven cavity to about 700 - 800 degrees F. With one of the elements not working, there's a good possibility the self-cleaning function will not work either Double check the items I mentioned and let me know if this helps you.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
