The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
SOURCE: GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
SOURCE: GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
SOURCE: GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
