20 Most Recent GE Profile Harmony WPGT9360E 4.0 Cu. Ft. Washer Questions & Answers
When spinning, Out of balance message occurs, then
it could be weak shocks for the drum or the springs. you can also overload the washer. there should be a gap in filling washer with clothes around 5-to 6 cm's on the drum ring this gives space for movement and balancing. the washer can also become out of balance if the bearing is damaged, if you can lift the drum from the bottom of the ring and it moves up and down by few millimeters and feels lose then its usually a sign the bearing is weak. this can make the display say there is a problem with balance. 6kg or 7kg is the weight of the clothes and water not the clothes. over loading the washer damages the bearings and put more pressure on the shocks and springs.
7/3/2017 6:02:47 PM • GE Profile... • Answered on Jul 03, 2017
I just washed my whites
if this problem is due to well water,,ocassionally use a product called White-Out,,,very good at removing rust stains and keeping washer clean of them.
2/16/2011 4:32:34 PM • GE Profile... • Answered on Feb 16, 2011
Notice a problem has been deteced with this unit
press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
4/20/2009 11:12:34 PM • GE Profile... • Answered on Apr 20, 2009
Won't continue cycle the message is
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and let you see any stored errors.
4/20/2009 3:53:24 PM • GE Profile... • Answered on Apr 20, 2009
2answers
GE Harmony washer will not move from problem notification screen.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
4/20/2009 3:50:00 PM • GE Profile... • Answered on Apr 20, 2009
3answers
How to get to heating element on ge dryer
my dryer heating is not turning on
3/5/2009 6:31:17 AM • GE Profile... • Answered on Mar 05, 2009
Ge harmony washer detect motor not operating proplerly
yes.
2/27/2009 2:37:29 PM • GE Profile... • Answered on Feb 27, 2009
Not rinsing correctly
it is most likely that the area is bloked pure bleach in it and run it throw a rince without clothes then after that put hot water in the softener area and run it agian on rince it should work
1/5/2009 1:27:28 AM • GE Profile... • Answered on Jan 05, 2009
I have an electric GE
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
12/12/2008 11:22:27 AM • GE Profile... • Answered on Dec 12, 2008
Close the Lid problem on GE Profile Harmony
Kevin, the switch is magnetic operation. You will have to remove the top to get at it. Do this by removing the back panel. Inside the panel on the left side will be 4 harnesses. Disconnect them. Remove the pressure switch hose from the tub. Remove the ground wire. In back on each side of the top panel there will be 2 phillip screws, remove them. Now lift the top from behind and slide foward. The whole top comes off. The lid switch will be on the underside just in front of the dispensor. You can test the sensor by using a magnet. Just open the lid and place a magnet just in front of the dispensor on the left side. The washer should work with the lid up. Catriver
11/30/2007 2:30:11 AM • GE Profile... • Answered on Nov 30, 2007
2answers
GE WSLP1100A0WW not agitating
It sounds like the clutch is slipping https://www.google.com/search?q=GE+WSLP1100A0WW+not+agitating
Top Load Washer - Fills But Will Not Agitate
GE Appliances https://products.geappliances.com > appliance > gea-sup... If the lid switch probe or magnet is missing or damaged, the washer will not agitate or spin, even with the lid closed. Missing: WSLP1100A0WW ‎' Show results with: WSLP1100A0WW
SOLVED: GE WSLP1100A0WW not agitating
Fixya https://www.fixya.com > ... > Washing Machines > GE 17 hours ago - Ge top loader washer agitator does not work To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator.
Ge Washing Machine - Washer Won't Spin Or Agitate
Repair Clinic https://www.repairclinic.com > RepairHelp > Ge-Washe... If a washer is not spinning or agitating, you should first determine if the drive motor is running and if power is reaching the drive motor. If no power if ... ..
4/21/2024 6:22:15 AM • GE Washing... • Answered on Apr 21, 2024
Can I get new brushes for my GE handmixer 56M17
No there’s no brushes for GE handmixer
3/10/2024 8:12:40 PM • GE Washing... • Answered on Mar 10, 2024
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather Good to see you again. Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely. One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe. ..
2/23/2024 8:08:04 PM • GE Washing... • Answered on Feb 23, 2024
2answers
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
12/11/2023 6:33:13 PM • GE Washing... • Answered on Dec 11, 2023
2answers
GE Washing Machine model GTW330ASK0WW. It won't run, no sounds, display comes on and after 15 seconds shuts down.
Question edited for clarity 'MAKE model (WHAT IT IS)'. You posted to Televisions, moved to GE Washing Machine. It may be the lid lock, test it with your digital multimeter. Look for loose or damaged connections. https://www.google.com/search?q=GE+Gtw330ask0ww+not+running ..
10/21/2023 3:04:17 AM • GE Washing... • Answered on Oct 21, 2023
2answers
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation.
check under agitator possible worn cogs
10/21/2023 3:02:47 AM • GE Washing... • Answered on Oct 21, 2023
2answers
Why wont My ge washer drain
check voltage to pump if ok bad pump also check drain hose
10/21/2023 2:59:12 AM • GE Washing... • Answered on Oct 21, 2023
Ge washer h20 supply error
Check the water level sensor.
10/12/2023 7:52:46 AM • GE Washing... • Answered on Oct 12, 2023
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. Washer Logo
Popular Tags
27 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
continue cycle message
  • Washing Machines
