I just want to know does this Camra even take videos If yes could you please tell me how to I can't seem to figure it out
Yes, the DMC-FZ20 can record videos in 320x240 resolution. Refer to the "Motion image mode" section on page 56 of the manual.
Take it to Walmart and they can get it working for you what I had to do
SOURCE: Lumix LS80 video camera no sound
Hi, i had the same problem 4 ages. every time i tried to playback my videos there was no sound, i did so many videos trying to get the sound going and then i played them on my computer and ther was sound, :) lol i felt like such an idiot when i found out there's no speaker on the camera it self.
SOURCE: How do I delete a picture on the Panasonic LUMIX DMC-LC40
When reviewing the images on the LCD with the image you want to delete showing on the screen you push the button that has a trash can icon. The camera will ask you if you want to delete the file yes/no; scroll to yes and use the right arrow button to confirm.
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
SOURCE: lumix DMC- FZ30 - screen is black when camera is turned on
I understand that you've tried all the obvious tricks like resetting to factory settings etc.
Sounds like a CCD/shutter failure I'm afraid. FZ30 are not known for failing CCDs, but I've seen shutters fail on various lumix-es, so in this case I would suggest replacing the shutter. To be precise, replacing the shutter itself is a massive pain in the **** on this camera. It's much easier to replace the whole lens-it contains the shutter. You'll need to get a donor camera (ebay ;) and do the transplant. Swapping the lens is relatively easy if you're ok with midly fiddly things. Oh, and make sure you take notes which screws go where when dismantling the camera - and be careful with ribbon cables for the LCD.
Good luck,
Raf
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
