I can change all info for other mailboxes in the company but not mine (#221). I tried to do it from another phone: not working. Is my extension number assigned to another number in the admin system?
SOURCE: I am locked out of
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Testimonial: "OMG THANKS SO MUCH!!!!!!!!!!!!!! YOU FIXED IT!!!! THANK YOU THANK YOU!"
SOURCE: NorStar T7316E Corded Phone Problem - mailbox locked
You will need to dial into the system admin of the voicemail
Feature 983
the password is dependant on how many digits your extensions use. 1020000 for 3 digit and 10020000 for 4 digit, 120000 for 2 digit.
go through the screens
Mailboxes, modify, scroll to password and press change.
Will reset to 0000.
SOURCE: Log #
If you are not the System Administrator/Coordinator, your phone doe not have this privilege.
Please use the Feature 981 enter your password. You really should ask your Administrator to delete your mailbox and re-add it.
