Tiene una mancha en el display
Just press your finger anywhere on the screen and it will turn darker around that spot.
You obviously warped the outside lid of your laptop. See if you can take
the lid and the LCD apart and straighten the lid to relief the
LCD-pressure from behind (literally...)
Thanks for your tip, i'm gonna try. I wanna translate my problem for those english speakers. ** Hp L1730 (P9625A) has black stains on the display. When the computer is switched on a dark stain appears on the display monitor at the bottom middle right, as if the pixels in that area were burned or do not turn on those pixels. The remaining area has a clear image. I do not think the stain is due to hit because the surface of the LCD is fine. Please could give me a tip or trick as reducing to a minimum the stain? Thank you.
