Amana dryer wont run fault code is a symbol that looks like an upside down F 5 beeps while displaying code , I have replaced the THERMOSTAT & THERMISTOR
Amana dryer won't run, fault code is a symbol that looks like an upside down F 5 beeps while displaying code... I have replaced the THERMOSTAT & THERMISTOR and still get the fault code !
The dryer is indicating that the door is open. If you can verify that the door is latched, the latch mechanism or the control board may have been damaged during heating coil replacement.
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed):
- Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
Heater unit faulty
Wiring faulty
NTC sensor incorrectly calibrated/out of position
Electronic board faulty
E62 - Power reley to heater unit faulty
Heater unit faulty
Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
test the thermostat and thermistor too and replace, if the problem persist, clean the ducts, or need to replace the control board if the problem . If the problem continue make this test. 1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be
displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read
it. 3. Press SENSOR DRY and TIME keys for 3 seconds to clear it. 4. Power OFF to exit Service Mode 5. Power ON
The upside looking F is really a lower case T and the 5 is an S. The code ts is related to the Thermistor which is on the outside of the blower housing. The part runs about $30
make sure you are getting full power to the heating element. if not check the thermostat at heater the one further back for continuity. it should beep or read "0" ohms. if not replace it.
okay after looking up everything sounds like you need to replace the thermistor they definitly cant be jumped off and it should be under 10 ohms. Get the model number and goto your local parts house they should have that on there shelves and replave it should work after that.
I have a gas model but this is what I found on the sight and it helped :
dt63
2 SolutionsFebruary 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
it.
5. Power ON
press the clock button to set the time. Press the "up" button which looks like a triangle symbol or the "down" button whih looks like a triangle upside down symbol until the correct time is on the display , then hold in the clock button for 5 seconds for the time to be displayed.
Amana model numeber NDF7200TW Gas Dryer
