My dryer has an E68 readout on the panel with a good deal of associated bleeping & flashing. If I unplug the unit for awhile & gently
push the buttons it will dryer just fine but if I leave it plugged in for
any length of time without drying the E68 reading returns.
SOURCE: Receiving an E68 readout on the time screen & lots of bleeping
E68 is a control assembly problem.
Try first unplugging the power cord for ten minutes.
If that does not work, then do the following:
Press buttons lightly and release.
Disengage button.
If still no luck, then the control assembly is defective and must be replaced.
enter model number here to get replacements., call them at the number listed if you cannot find the model number.
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
SOURCE: i have a frigidaire affinity dryer that will dry
Run the service diagnostic mode to determine which button is stuck. Start by pressing and holding the Select and Cancel buttons simultaneously for 6 seconds to reset the control.
Rotate the cycle selector knob 5 turns counterclockwise to the second position from the bottom immediately after the buzzer sounds.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control enters the test mode and the buzzer will sound 3 times with all of the LEDs flashing.
Rotate the cycle selector knob 4 turns clockwise to the second position from the top and the dryer motor runs with the heating element off. The buttons can now be tested to determine which is stuck.
Press each button and all corresponding LEDs should light. If the LEDs corresponding to a certain button lights up without pressing the button or if the LEDs do not light up when the button is pressed, that button must be stuck or not making any contact when pressed.
Replace the control board if the stuck button cannot be unstuck or if there's no button that's apparently stuck but the fault code persists. Let us know if you need further advice.
SOURCE: frigidaire affinity elec dryer model
Your control is faulty and will need to be replaced. Access to it is gained by removing the top panel.
Kelly
