SOURCE: Hyundai Santa Fe 2005 won't shift into first gear
Most likely the o-ring seal between the torque converter and the transmission is going bad. Get that transmission rebuilt pronto before serious damage is done! But first, have a mechanic drop the transmission pan and look for signs of a very thin silvery film coating the inside of the pan. If found, then the transmission definitely will have to be rebuilt, and the torque converter will also have to be replaced since embedded metallic particles in the old torque converter will eventually come loose, due to wear of the clutch plates within the torque converter, and eat up the rebuilt transmission. Now, here is the deal once the transmission has been rebuilt:
Change the transmission fluid and filter once a year -- no matter what! If you do this, then you should never have any more problems with the transmission.
SOURCE: My 2005 Hyundai Santa Fe shifts really hard from
If there is no check engine light on - check the transmission fluid by pulling out the dip stick (check the level and smell the fluid if it smells burnt, there is an internal problem with the transmission) if all this is ok then the problem may be one of the speed sensos or (pulse generators)
SOURCE: i have hyundai santa fe 2005 4cyl .. transmission not shifting .. always in 3rd gear ..
Hello
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully
electronically controlled by a computer called the PCM and TCM (Power
Train Control Module, Transmission Control Module). When a problem
like this or other drive-ability related problems occurs the computer
stores a record of the problem (there are of course some exceptions
to this, like the fuel pump, engine coolant temperature sensor and
MAF sensor for instance) in the form of a fault code in its memory,
to read these fault codes you must have the systems memory scanned
with a special tool. Once the fault code(s) are read you then must
perform the appropriate diagnostic testing to find and resolve the
problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED
TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD
EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always
check fuel pressure for correct spec for your make and engine type.
SOURCE: When accelerating in 2nd and 3rd gear my Hyundai
Check the ignition system. It may work fine while idling but fail during acceleration. Problem areas to be inspected include the spark plugs, spark plug wires and vacuum hoses. You should look for spark plugs that are covered in oil or sediment or damaged, spark plug wires that have damaged insulation, and vacuum hoses that are unplugged or leaking. The use of a fuel additive that contains both fuel injector cleaner and water remover can fix minor problems due to water in the gas and fuel injector clogs. Check the fuel pressure to test the injection system to assure proper pressure.
Bad ball joint. Replaced it, problem fixed.
