Unfortunately browsing to the printers IP address does not work and there is no Protocol Information on the Configuration Page. Only the following
Printer Information
Memory
Event Log
Security
Installed Personalities and Option
Paper Trays and OptionsUnfortunately browsing to the printers IP address does not work and there is no Protocol Information on the Configuration Page. Only the following
Printer Information
Memory
Event Log
Security
cannot ping, get timeout, cannot log into it 10.1.1.55, do not have a port called RJ45, don't have manual helpcannot ping, get timeout, cannot log into it 10.1.1.55, do not have a port called RJ45, don't have manual help
AnonymousMar 19, 2014
i want to know set ip hplaserjet 8150i want to know set ip hplaserjet 8150
You can't post conmments that contain an email address.
1. Launch your web browser.
2. In the Address: or Go to: field, type the IP address assigned to the
printer (for example: http://192.168.1.1) or the host name (for example:
http://myprinter).
If you do not know the IP address for the printer, it is listed on the
printer configuration page under Protocol Information in the TCP/IP
section.
To print a configuration page:
a. On the printer control panel, press Menu until INFORMATION
MENU displays.
b. Press Item until PRINT CONFIGURATION displays.
c. Press Select to print the configuration page. After the process is
completed, the printer will return to the READY state.
Try plugging it in to the network, then print a configuration page (after a minute or two).Try plugging it in to the network, then print a configuration page (after a minute or two).
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following - 1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly. 2. Install the HP printer driver on your computer/s using the LPT printer port. 3. Connect the printer with a LAN cable to the network hub/router. 4. Click on Printers and Faxes - right click on the HP printer and click on Properties. 5. Click on Ports and click on Add Port. 6. In available ports - click on Standard TCP/IP Port and then Configure port. 7. Tick the IP box and type in the IP address of the HP\'s printer IP address. 8. Click OK and tick Enable bi-directional support and then OK 9. Remove the printer cable, then do a test print to see if the printer prints correctly. Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer. You can now print from any computer on your network.
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display. 2. Press Item until PRINT CONFIGURATION appears on the panel. 3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following - 1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly. 2. Install the HP printer driver onyour computer/s using the LPT printer port. 3. Connect the printer with a LAN cableto the network hub/router. 4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties. 5. Click on Ports and click on AddPort. 6. In available ports - click onStandard TCP/IP Port and then Configure port. 7. Tick the IP box and type in the IPaddress of the HP's printer IP address. 8. Click OK and tick Enablebi-directional support and then OK 9. Remove the printer cable, then do a test print to see if the printerprints correctly. Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer. You can now print from any computer on your network.
To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following - 1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.xxx then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network).
If you have a wireless router then check the IP addressrange that the router issues to the computers on your network and configure thestatic IP address in the printer's network configuration accordingly. 2. Install the HP printer driver onyour computer/s using the LPT printer port. 3. Connect the printer with a LAN cableto the network hub/router. 4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties. 5. Click on Ports and click on AddPort. 6. In available ports - click onStandard TCP/IP Port and then Configure port. 7. Tick the IP box and type in the IPaddress of the HP's printer IP address. 8. Click OK and tick Enablebi-directional support and then OK
Every network printer or print server has a unique IP address associated
with it. This address is either configured manually or set using an
automatic network protocol such as the boot protocol, reverse address
resolution protocol or zeroconf. You can normally find the IP address of
a printer on the printer's control panel or by printing the
configuration page. Select the printers and faxes tab from the control
panel. Right click on the printer those you want to find the IP address
and click properties. Then click on the ports tab to display the IP
address of your printer.
First, make sure your Network Interface is working properly. Print a test-page. Menu--->Information------->Print configuration-page. If your machine print only one page, your interface doesn't work right. If your machine prints a configpage and a seperate network-page, you're good to go.
The easiest way is to look at the network-page and see if the machine already got a ip-adress. If it already got a ip-adress (DHCP), type that adress into your favorite web browser and do your config from the machine's web-interface.
Or you can access the printers menu.
Menu---->I/U---->EIOx settings---->TCP/IP----> and set your settings as you wish. Good luck.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following - 1.Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly. 2.Install the HP printer driver on your computer/s using the LPT printer port. 3.Connect the printer with a LAN cable to the network hub/router. 4.Click on Printers and Faxes - right click on the HP printer and click on Properties. 5.Click on Ports and click on Add Port. 6.In available ports - click on Standard TCP/IP Port and then Configure port. 7.Tick the IP box and type in the IP address of the HP's printer IP address. 8.Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed. Do a test print page to check the printer. You can now print from any computer on your network.
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Printer Information
Memory
Event Log
Security
