Kodak EasyShare V1003 Digital Camera Logo
Posted on Dec 11, 2008
Lcd cracked and bleeding spot down left part of screen
Lcd of my v1003 kodak easy easyshare, I would like to get it repaired , where do I go, or how do i solve this problem and how much would it be, thank you
Anonymous
Level 1:
Genius:
  • Contributor 1,199 Answers
  • Posted on Dec 11, 2008
Anonymous
Contributor
Level 1:
Genius:
Answers
1199
Questions
0
Helped
391092
Points
28
Go to www.kodak.com look for the customer service link or look for contact us ,then call and they will give you a return number
Hope this was of help!
3helpful
My lcd screen cracked.can this be fixed.their is no picture
Hello
Yes, your LCD display can be replaced at your nearest camera repair store for about $30.
Kind regards
Andrea
Kodak v1003 screen has 3/4
tap the screen and see if any changes happends.if not, you need a new display.on rough impact such issues usually apears....sorry for my english
My LCD screen has a dark spot
The screen must be replaced. To do it yourself, the screen will cost around $40 from virtualvillage dot com. I just did one. It took about 15 minutes. The ribbon cable is held in by a flip up lock on the main board. Otherwise, it's just remove the screws around the case and pull the bottom edges outward first.
virtualvillage uses Pay Pal only.
Cracked screen
no the screen is not worth gettin fixed the lcd scrren usaually cost more than the camera itself does but if your camera is discont get it fixed because their will be no other camera like it
White Sreen
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
Best of luck
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
