Check
my tipUsing Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
I'm using the Belkin N wireless router with tesco Broadband. My Zoom adsl x 4 modem works fine but when i try to set up the wireless Belkin, it says my user name and password are not right and it will not connect to the internet
Sometimes when we start the laptop we have no connection th the internet. When I open the network center, I see that the connection from my laptop to the network is marked with a yellow exclamation mark, and the connection between my network and the internet is marked with a red cross.
When I reset the router, the problem is fixed and everything is fine...
Also, when we startup a laptop, there is no internet-connection until a connection is asked (e.g. by trying to download emails, trying to browse any existing website, etc...) This was not so like a month ago...
Is there a solution for both problems?
Thanks.
