20 Most Recent Dynex Enhanced-G Wireless Broadband Router Questions & Answers
Installing wireless g router on macs
Router setup
You do not have to use the cd.
Shutdown your Mac. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your Mac. The Mac should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider.
After you get the Internet to work via the Lan (wired to the Mac) you can disconnect the network cable and use the Aiport to go wireless.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
11/5/2015 12:29:29 AM • Dynex Enhanced-G... • Answered on Nov 05, 2015
My computer went down and
Download what you need from here. Drivers are zipped up and you may want to download the manual to walk through the settings.
http://www.dynexproducts.com/products/computers/DX-WEGRTR.html
6/14/2011 5:03:02 AM • Dynex Enhanced-G... • Answered on Jun 14, 2011
Where can I find the
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
2/1/2011 1:52:18 PM • Dynex Enhanced-G... • Answered on Feb 01, 2011
I can not find the
hi. I think I can help you with this.
First, make sure internet is directly connected to the router with a lan cable from the cable modem.
Next, connect your laptop to the router's lan ports with a lan cable, instead of attempting to connect to it wireless-ly.
Next, open a browser, and go to this address: 192.168.2.1
Next, if you didn't assign a username and password, when it asks for them, leave them blank, and press enter
If you have already given it a username and password, use them to log into the router.
Then, go into security setting and select a security level...i.e. wep, wpa, and so on, and give it whatever you want to have for those, but make sure you write them down, as you will need them to log into the internet, as well as logging into the router page.
After you do everything you need on settings, click the save button if there is one.
If not, then click log-out
Next, disconnect the wire from the router to your laptop, and unplug both modem and router.
Next, plug in modem first, and wait 45 seconds for it to initialize, and then power up the router.
Within about 30 seconds or so, it should initialize, and be ready for you to use it.
Thenlog on to that internet connection, and enter the username and password that you gave the connection, and you should be good to go.
1/25/2011 2:30:40 AM • Dynex Enhanced-G... • Answered on Jan 25, 2011
My computer is no longer
try to use admin admin or user user. if doesn't work reset your router and configure it again using
your router manual.
1/20/2011 10:02:06 AM • Dynex Enhanced-G... • Answered on Jan 20, 2011
I forgot my password. how can I change the
if you mean that you forgot the WEP, you can log in to the administration page of the router by connecting directly with an ethernet cable and change it.
If you are talking about the administration page password, you can press the reset button of the router and then you will be able to log in with the default password. See your manual for more details about doing this.
Regards,
1/12/2011 12:39:07 AM • Dynex Enhanced-G... • Answered on Jan 12, 2011
2answers
I want to connect to my Kindle wiFi and I need a
If it is your Wi-Fi network you are trying to connect then you would of set up a password when you set up the network. If you did not set up the network ask the person who did. If you have a computer you connect to the same network with, use the password you used to connect the computer. Hope this helps :).
12/8/2010 8:11:07 AM • Dynex Enhanced-G... • Answered on Dec 08, 2010
The installation wizard is not recognizing the
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
11/27/2010 4:54:33 PM • Dynex Enhanced-G... • Answered on Nov 27, 2010
My connection is unsecure and
Make it secure.
Log on to the router and set your security to WGA2.
If unsure how to do this, google your model and setup for a guide
10/11/2010 9:18:24 PM • Dynex Enhanced-G... • Answered on Oct 11, 2010
I need to find my security code for my dynex
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
10/4/2010 4:17:38 AM • Dynex Enhanced-G... • Answered on Oct 04, 2010
Hi, how do i find the "WEP" on my router?
use a hard wired computer and go to command prompt . follow this ...
1) xp computer :start ->run ->type cmd
vista : click start ->first box at the very bottom start search - type there -cmd and enter win 7 : same as vista 2) type ipconfig 3)make a note of default gateway (could be like 192.168.2.1) 4)type the same numbers on the address bar on IE (without http or www) and hit enter 4)router setup page will appear , select the wireless security part 5)you will find the wep key there
10/1/2010 8:34:21 PM • Dynex Enhanced-G... • Answered on Oct 01, 2010
Router is locked. Don't
Reset the router back to its "factory" specifications.
Then, you can configure the router, and enter a SSID of your choice, an encryption-level (use 'WPA') and enter a password of your choice.
9/22/2010 12:37:59 AM • Dynex Enhanced-G... • Answered on Sep 22, 2010
My router lights all turn lime green, and they are
It is in a constant reboot - it is no longer any good
7/10/2010 10:35:44 PM • Dynex Enhanced-G... • Answered on Jul 10, 2010
Cannot remember my password. Is there a way to
There is no way to retrieve it but you can do a hardware reset of the router which will take it back to factory defaults and allow you to set it up again.
Unplug it and look for a reset button these are generally recessed in so will need a pen to push them in.
7/1/2010 12:55:25 PM • Dynex Enhanced-G... • Answered on Jul 01, 2010
Stopped working with internet modem
Do you have another router to try? What exact problem are you getting? Can you still access the router itself?
Thank you,
Lee
6/30/2010 11:05:24 PM • Dynex Enhanced-G... • Answered on Jun 30, 2010
Need disc for dynex dx-wegrtr
You can confiure your without disk too .
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
6/7/2010 3:30:40 AM • Dynex Enhanced-G... • Answered on Jun 07, 2010
Trying to find my mac address on my dynex wireless
It will say on the bottom of the router.
4/6/2010 5:09:49 AM • Dynex Enhanced-G... • Answered on Apr 06, 2010
Dynex Enhanced-G Wireless Broadband Router Logo
Popular Tags
64 questions posted
Top Dynex Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Computers & Internet
Most Popular Question
forgot password change
  • Computers & Internet
