Indoor unit showing red light blinking in nine times, ac can not start please help me what i do.
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
SOURCE: Have a Multi Split Indoor unit ASU9RD - 2 units
Hi.
Here error codes:ERROR CONTENTS
Here a complete service manual.
Here user manual.
Before doing anything else, power down the main circuit breaker, so to power down each unit and reset the electronics in the whole system. If all units have gone down at the same time, this will often solve the problem.
Regards.
Ginko.
SOURCE: Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
