SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
SOURCE: model 150T Ironman Treadmill..motor has gone out
http://www.ironmanfitness.com/docs/man/treadmills/man-150t.pdf
there is the manual, but I need more info on your motor problem and what kind of belt adjustment you need to make.
SOURCE: Ironman M2 treadmill starts but then stops right away
Most treadmill will run for a second or two but stop if the speed sensor don't pick up a speed. If the treadmill was moved there is a good possibility that the sensor is off line. Not 100% fimiliar with this particular unit but if you remove the motor cover, these are the usual places for speed sensors. The front roller- the side where belt come from the motor. The other popular place is on the motor fan. The sensor has either two or three wires with the sensor at the end. On the roller, the sensor needs to be close enough to pick up the magnet on the side of the roller. On the fan make sure the teeth are clean and sensor has a good connection. Hopefully one of these will do it for you.
SOURCE: My treadmill belt just stopped, message error E
Unplug your unit, then remove motor shroud have a good light the sensor is either mounted on the frame by the front roller/pulley unit or it is mount on the motor sometimes by the flywheel sometimes on the opposite end. Next step is to locate the motor control board and plug you uit in. Your board should ligt up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flicker or not if it does then the sensor is working , then we other issues, if not either we have a defective or misalign sensor. An if your unit needs lubrication use a synthetic silcone product.
SOURCE: Error code "SI 2" for ironman triad treadmill
You need to replace the motor control board located in on the base. If your both motors work along with your display added that you've done the reclibration then you must replace this board. I did and the unit works so far. 200 dollars is what you wil be spending.
