20 Most Recent
Ironman Fitness Achiever Elliptical Trainer Questions & Answers
Owners manual
We lost ours in a move too!
It plugs in near the bottom/front on the R side of wheel cover.
What are the specifications of thr replacement? How many volts output, etc?
Thanks
It is squeaking.
Just remember that the number one cause of failure of the motor controller is high walking belt friction. I always make sense to replace the walking belt when you are replacing the motor controller on the Iron Man Treadmill.
There is no resistance on my ironman achiever, can
I have the same problem and took mine apart. There is a steel cable running from the resistance controller servo to the magnetic brake assembly and inside the assembly two more that attach to the brake shoes. In my case both of the small inside cables broke but if the main outside cable or any part along that chain broke it would have the same effect. I've emailed about replacements. Take care if you open this beast. It's a bugger. Take lots of snaps along the way sow you can see how it goes back together.
