During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to your desired device ,press escape then press f10 to save to cmos to restart boot from a usb drive hope this helps
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
SOURCE: does my motherboard support USB booting, and if so
press dell when you start pc go to setup of system and change boot option to usb device
SOURCE: i want to boot from usb but my motherboard has no option to boot
Yes, it is possible to boot to a USB device, even when there is no support in the system BIOS for such a feature. To do this you would need to install a freware utilty, a boot manager, called the PLoP Boot Manager. The PLoP Boot Manager is a small program to boot different operating systems.
You can boot the operating systems from harddisk, floppy,
CD/DVD or from USB.
You can start the boot manager from floppy, CD, network and there are many more ways to start the boot manager.
You can install the boot manager on your harddisk. There is no extra partition required for the boot manager.
It can be found at: http://www.plop.at/
SOURCE: no beep and computer suddenly stop working.
1. May be u have a small PWR supply. Late MB need a bunch of power 350W or more.
Or maybe some interface card/disk use to much power/short circuit.
2. If your computer poweroff just after u write userid and PW may be you got countdow virus or similar.
Try to put in the cd a LIVE distro like UBUNTU, boot from it and wait.
If your computer poweroff u got an HW problem (see #1) if it stay on u got the virus.
if you want to save data you have in the computer just boot a LIVE distro and copy them to an external USB disk.Run an antivirus on external disk: may be you have copied the virus too.
if you are smart enought you can run a stand alone specific antivirus, if not
call for service.
claudio
SOURCE: HELP ME PLEASE...i have asus P4P800 SE but
there is problem with your motherboard
change your motherboard
it is at fault
SOURCE: I have an Asus K8N-E
you could possibly try a BIOS update to see if ASUS added it. If not than you will have to boot from HD or CDROM or floppy if need be!
