20 Most Recent
Compaq Mini 110c-1001NR Notebook Questions & Answers
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
How do I unlock stuck keys
Likely there's some foreign stuff under the keys, like spilled drink. Pull the keys up gently, and use a damp cotton swab to clean underneath.
New battery won't charge
Some inexpensive batteries do not play well with your laptop. Take a look at "Plugged in, not charging" SOLUTION!!!" :http://forums.cnet.com/7723-19681_102-345945/plugged-in-not-charging/
When i turn it on all it says is bootmanager missing
If your Windows 7 or Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows DVD handy.
