Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
Anonymous Posted on Jun 27, 2012
TV will not turn on with either the remote or the switch. Tried resetting it by unplugging and waiting 5 min then replugging but nothing
  • Anonymous Jun 27, 2012
    Not exactly helpful. I am not much of an expert but I figured it was broken...
4 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Jul 07, 2008
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
A
Anonymous
  • Posted on Jul 20, 2008
SOURCE: Doesn't turn on, but LED blinks 5 times
ws-65511 no power up
problem
Anonymous
  • 666 Answers
  • Posted on Apr 03, 2010
SOURCE: Sony 29FQ65E is turns off between 2-25 min
try to replace crystal capacitor near jungle ic, and let me see if the problem still occur.
caroldon
  • 17130 Answers
  • Posted on Sep 30, 2010
SOURCE: hi i have the sony
Possible failure in the horizontal section of the horizontal driver or the failure of the line output transformer.
You will have to disconnect the +B to confirm if the SMPS gives the power.If so check for short in this section .
respond.
My TV wont turn on- no power at all
Is the TV totally dead or do you have a standby light?
2answers
RCA 36695BC wont turn on
Can you please provide the chassis number of this TV?
2answers
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
The tv turns on then just turns off.I have a receiver that works.
unplug for 5 min. replug and go. if no go then perhaps the remote needs batteries or needs resetting. otherwise you may need a module replacement for the power transformer.
Friedrich WallMaster PH12K3SB-3 Heating and AC
try to unplug it. wait 5 min and replug it. this resets the electronics
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
2helpful
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
5helpful
2answers
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
