2 or 3 beeps at start up they are error codes of some kind and do not know which error code it is. It sounds like 3 beeps when booting up but not sure it isnt 1 beep followed by 2 more beeps does this make sense? It was making a horrible noise a few months ago every-time the virus scanner would run sounded like it was getting ready to take off into space. But it did not make that noise all the time. I thought I had fixed the problem by replacing batteries in the cordless keyboard but it worked for a few days than again continued to start up with the beeps again. unplugged everything externally. Now what should I try? Thanks in advance for any of your help. have a great day.
That will generally indicate a major system problem on just about any PC. On your PC it should be indicating an issue with the video subsystem. These problems are not always fatal so it might be as simple as pulling the power and battary for a full system reset or you might need to do a firmware reset. at any rate I am not an expert on Acers so hear is a link to the Acer help site with the exact error you are having and they did get it fixed. take a look.
https://community.acer.com/t5/2013-Archives/Aspire-T180-won-t-boot-and-is-making-a-beeping-noise/td-p/29389
SOURCE: I have an Acer Aspire (and thats as much as I
thats usually a software problem, that happens when the CPU gets overloaded and there's still data input coming in! Try formatting the disk and if the beeping sound persists, open the case and look for bad connection between the main componentsand the motherboard
SOURCE: acer 180 ES320M, computer starts booting then long
Sounds like the memory is not seated securely. Open the case remove and reinstall the memory to insure it is securely seated and connected.
SOURCE: My Acer Aspire M6540 didn't
first you can try change your psu but you can tray also remove the CMOS BATTERY for a few minutes and see whats heppend when you pu it back
SOURCE: My Acer Aspire M1201 Desktop
I have same problem, My machine switches on fans run but no beeps ??? HELP ME PLEAE
