Dell 924 All-in-One InkJet Printer Logo
Posted on Jul 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cartridges replaced- top closed- no way out of manual
After replacing a cartridge and closing the top, the manual does not disappear and message keeps coming up the (scanner) top is still open, which is not. when i closed it i had to use a bit of force as it seemed the handle was a bit stuck.
on my island is no Dell technician available and i have been told this type of printer is similar to a Lexmark???
Any advice, solution or direction is most welcome. Thank you in advance.
  • cpacjn Dec 05, 2008
    How do you install the ink cartridges? I can't see the location.
    Must I "unscrew" something? I lost the Manual for my HP 924
    Carlos J
John In Milford
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Jul 02, 2017
John In Milford
Expert
Level 2:
Sergeant:
Answers
200
Questions
Helped
112271
Points
628
Completely disconnect this unit. Power, usb etc. hold the power button for 30 seconds. (it obviously won't turn on, but humor me) Then open all the doors on the unit, paper jam, ink cartridge access, and ink cartridges also/ etc. Close all doors again, then connect to the computer, then the power, then power on. If the problem persists, you broke the sensor or it's little plastic tab, which might not be worth replacing.
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Dec 30, 2006
SOURCE: printer error message
To eliminate a software problem, disconnect printer from pc and completely uninstall the printer driver and restart pc. Insert our printer driver cd and install the drivers, but do not connect printer until advised. When advised connect printer and ensure windows recognises it in the little pop up window in tool bar and says 'Your hardware is installed and ready to use' If the same message appears then the printer is faulty.
Anonymous
  • 3 Answers
  • Posted on Dec 29, 2007
SOURCE: Dell 922 "cover open" problem / error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then close the printer after it powers on.
It worked for me.
Anonymous
  • 59 Answers
  • Posted on Jan 07, 2008
SOURCE: Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
SYED KHAN
  • 41 Answers
  • Posted on Apr 26, 2008
SOURCE: dell photo 924 ink cartridge problems
Hi ,
if you are getting the msg color cartridge missing , maku sure that it is compatible with your printer , on the cartridges you will get the part no M4646/J5566 , look for those part no's and if it is giving the error msg on the LCD display of the printer , try using the old cartridge ...try the following steps
1) put the old cartridge in and then unplug the power adapter (Black box ) from the printer.
2) wait for 30 seconds and put back the power adapter and turn on the printer, and look for the msg on the printer display. if it gives the same error msg with the old as well as the new color cartridge then its an issue with the printer , and if it does not gives the error msg with the older one then its an issue with the cartridge and if you have purchase the cartridge from dell online/phone then call them back give the order no of the cartridge that u have purchased and they will replace it.
good luck..
Anonymous
  • Posted on Aug 23, 2008
SOURCE: Refilled my Dell Ink Cartridge
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
6helpful
Lexmark 6170 Cartridge Error 50C How to resolve?
"Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
2helpful
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
color cartridge.
6helpful
Cartridge error 50C
Hi there Error 50c
RegOk hope it works.
color cartridge.
4helpful
Cartridge error 50c
Hi there Error 50c
Please try this.
color cartridge.
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
color cartridge.
1helpful
2answers
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Error message "Cover Open"
try to put back the old cartridge if the message disappear ,means the new cartridge have problem. may be you buy a remanufacture one.
6helpful
3answers
Error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
