20 Most Recent
Lexmark P315 InkJet Photo Printer Questions & Answers
Lexmark p315
You mention two problems, are they both still active?
The memory card issue could be a defective card; I've had brand new cards not work a number of times. It could also be a defective card reader in the printer but its more likely the memory card may simply need to be re-formatted.
- Save any pictures you may have on the card to your PC if you need to keep them.
- Format the card using the camera utilities. Do not use the computer to perform the format.
- Try it again.
If formatting the card doesn?t do it you might try another card you know works. If it does work in your printer then its probably the card, if not that strongly suggest the printer card reader is at fault.
Let us know if you have any other questions and please don?t forget to rate this posting.
Prints pictures in green
As its very new, I think the best thing is to call their customer care as there might be a problem in Color Cartridge.
Printer does not read memory cards or card reader
Here's the list of compatible digital media memory cards:
- CompactFlash I & II
- SmartMedia Card
- Sony Memory Stick, Memory Stick PRO
- Secure Digital (SD) Card
- MultiMediaCard (MMC)
- Microdrive
- 4 Built-in Card Readers
- xD Card
- Sony Memory Stick Duo (with adapter)
Hello,I haven't been able to
To clean the cartridge via the operator panel, follow the steps below:
- Press the Menu button once. The Photo Menu will appear.
- Press the down arrow until Clean Cartridge (Press SELECT) appears.
- Press Select to begin the cleaning process.
- When the page has finished printing, press Stop/Clear to exit the Photo Menu.
However, if you have made several tries already yet cartridges are still not printing properly, it may be time for you to replace those old cartridges with new ones.
Source: How to
Clean the Cartridge on a Lexmark P315 Photo Jetprinter
HI .I HAVE A LEXMARK PRINTER NO; P315, PUT IN A
the issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again. But if you tried that and it doesn't work just call up their support number and check for replacement.
