Computers & Internet Logo
Anonymous Posted on Dec 03, 2008
Cpu can not boot
Hi all, good morning. I have a problem with my cpu, it's a fujitsu fmv. Before this, the cpu is running good. Then, last night i took out its ram (sdr 128mb pc 133 ecc) and put in another sdr ram to check wheather the other ram is good or not, but nothing happen (the cpu just blank meaning the ram is spoilt-right?)
So, i put in back the original ram (sdr 128mb pc 133 ecc) but still nothing happen.
I've check the ram, hard disk, ide cable, power cable, mobo, monitor, by swapping it with another cpu but still nothing happen. When i turn it on, only the windows xp logo come out then it hang and the screen just went blank BUT the monitor light keep blinking.
I really don't know why and what is happening. I just took out the ram, put in another ram-i didn't work so i put back the original ram and this is what happen. I'm confuse. Can any genius out there help me with my problem..? I really appreciate it..
  • Anonymous Dec 03, 2008
    Hi, thanks for ur help :-). I did manage to boot in safe mode, enter with admin. So, what should i do now? I did see any problem with the pc. By the way, i can also go to the bios setting.
Anonymous
Level 2:
  • Expert 341 Answers
  • Posted on Dec 03, 2008
Anonymous
Expert
Level 2:
Answers
341
Questions
0
Helped
149313
Points
907
I don't think it is a ram issue.Try this when the computer is booting,hit the F8 key. That boots you into safe mode where only the most necessary drivers and programs load. If it loads in safe mode that is good. A little bit of daignostic work can locate the problem after that.
    I would use "System Restore" while in safe mode to go back to a day before your problem started. Windows takes a snapshot of your computer once a day or any time you make changes to your computer.Simply pick a day from the list when you know your computer booted properly and follow the instructions. Get into system restore this way,
    Start,
    Accesories,
    System tools,
    System Restore
    Any other questions, just ask.
1helpful
Fmv biblo nb90j/t laptop is unable to boot
Laptops are usually running about 19.5 V and 65watts I suspect the power adapter is not powerfull enough. Check voltage and power requirements from laptop sticker on the back or instruction manual.
Driver fujitsu fmv-6100mg2 driver
Good loock,, use the google translate for this web page.http://www.fmworld.net/biz/fmv/index_down.html
Is there a way to increase its RAM from 1GB to 2GB? Or, are there other ways to make it run faster?
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
1helpful
2answers
Download drive vga fujitsu fmv 7000cl2
try this site http://www.softitem.com/driver-vga-drver-fujitsu-fmv-7000-cl2-drivers hope this may help you
It is not booting and display a message with blue background which disappear within a matter of second.
Boot from a bootable CD with the operating system not lower than the version you had initially in your Laptop and run recovery console. Write to me again if you dont know how to run the recovery console
I have a problem in My fujitsu FMV-665NU9E laptop.when i start it up then during booting show on screem operating system not found.help me about this issue that what i do.thanks
You have a hard drive error. You may have to insert your System disk and restore your system.
When you can get into your hard drive, run CHKDSK/F to check for errors.
Hope that helps
1helpful
2answers
I need drivers for Fujitsu FMV-675MG
here is the driver
http://www.filesonic.com/file/975199744/fujitsu_fmv_675mg.rar
best regards
yusa82
1helpful
Cpu won't detect nano pen-drive
I sold the nano pen drive to my friend :-) i just use a kingston pen drive. I think maybe the fujitsu fmv couldn't support/read the nano pen drive "cause i've installed the driver from imation web site but it still won't detect the nano pen drive.
FUJITSU FMV-BIBLO NB75M black screen
take it to the service center if you are not expert cause it is an internal problem
Grand Canyon Tech
Grand Canyon Tech
