Already connected to monitor and press f8 but nothing happens...
Did you press and hold the FN function key plus the key that toggles the
display? In your case it might be the FN+F8 if F8 is the key that
toggles the display. Shine
a flashlight on the dark screen to see if you barely see the icons on the
desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If the video shows on the
external monitor that proves your video card is ok, ,but your lcd screen is
bad. The video will show on most systems when you reboot without you having to
do anything. Some systems will require you to hit the FN (Function key) + F1
thru F12. Hold down the FN key then hit the correct key for displaying on
the monitor (F1 thru F12). The correct key will normally have CRT/LCD on
it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
If your video card is bad you will not see anything on the laptop's lcd screen or the external monitor.
SOURCE: when using external monitor i
need to configure the Graphics Properties, Right click over the desktop
SOURCE: my notebook is displaying there is a ile or corupt
I believe you want F9 not F8 but if that doesn't allow you to restore, you will need to load Windows onto a USB thumb drive and boot from the USB to repair the system. This probably will take a computer repair person to do this.
Here are the instructions:
1. Get a USB drive with around 10 GB capacity
2.
Format the USB drive with FAT32 (NOT NTFS, it will not boot with NTFS)
3.
Copy the ASUS Recovery CD to the USB Drive. Obviously, you will need a
computer that has a DVD drive.
4. Go to the 1005HA Bios and make the
USB drive the 1st boot option.
5. Insert the USB drive and reboot.
If you do a full restore, all of your data will be lost.
