SOURCE: frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
SOURCE: Our FAH086J112 Frigidaire Gallery Air conditioner
Get a bubble level and make sure the housing is sloped away from the house and yes remove at least one of the drain hole plugs.
Hello Ramona - Could the error code possibly be S or ES? If so, typically that indicates that there is a problem with the evaporator sensor. I would recommend contacting a professional to accurately diagnose and repair the air conditioner.
