Walt SATA controller goes bad on these motherboards. Disable sata in bios and install a pci-e to sata adapter in one of the pci-e slots on the motherboard. Windows 7 recognizes the adapter with no drivers needed and you can connect a dvd-rom and a sata drive. You will have to reinstall Windows 7 and you will be in business. The pci-e to sata adapter can be found on Ebay for $12 to $16.
Go here and select the operating system you are using and download the "Chipset Driver" and install it:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=4120567&
Also, recheck the connections to the drives, both power and ide or sata.
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make
sure they have a secure connection and are not faulty or just replace them they
might be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs all electrical power and data to travel through every working device its and
have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
During the boot process you
will see on the screen to press delete to enter setup
Press
and hold delete during the boot up process to enter BIOS
hope
this will help
No, That's not going to help. The unit won't post. I pulled the drive and put it in a jig and the drive and data are intact. That Pegatron mobo is known as a junker. This mobo won't pick up any drives.
Then it's time to get a new motherboard or a new computer.
Thanks everyone. I have elected to get a new mobo although let me clarify my issue: The unit would post and I could run diags and f2 into setup etc.. but when the post was finished the unit would not hand off to the drives under any scenario. Be advised that the Pegatron mobo sucks!!
