How do i open up back of laptop
SOURCE: I need to dismantle my Presario 700 (Series
If your Laptop is overheating, here is something you need to look into and rule out. http://bpr.hpordercenter.com/hbpr/ and here is the link to Your Model's Support Page on the Manufacturer's Website. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=99905&prodTypeId=321957&prodSeriesId=96403&swLang=8&taskId=135&swEnvOID=228 You can pretty much take care of Everything pertaining to Your Laptop from this Link.. OK? GOOD LUCK. Lucky4lynn2 p.s. PLZ rate me, k? Thank You
SOURCE: Compaq presario 700 series cm2130 LCD Screen
I have the same model of laptop; and not had a problem swapping with other X-series screens taken from Compaq/HP and IBM laptops. (My laptop is a bit 'incident' prone, and is +70% by weight replacement parts.)
As for assembly/disassembly and a (very) partial replacement part list, HP publishes the Service Manual(pdf) online.
Also, if you have a model with an aluminum heat sink take this opportunity to remove the sliver solder attaching the aluminum/magnesium heatspreader, and silver paste-- (someone in QC failed highschool chemistry, remember the galvanic series ?). A hard eraser will remove the worst of the rust, use an odd bit of pottery if you need a mirror finish. I then reccomend using a good latex-ceramic paste, your laptop will then avoid the spontaneous shutdown issue.
