I went to bed one evening and it was working. Fell asleep and when I woke up there was no picture. I did fall asleep with the remote in the bed. Could I have hit something on the remote that caused this - or did the screen just quit?
SOURCE: BASE tv/dvd combo- not toshiba but it looks like this model
I have the same problem with my Tv too. There is No phone listing and the number given on the warrant policy is no longer connected. I rang Target and Base is their own brand. If anyone needs it the contact number for Target head office is 1800 814 788.
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
SOURCE: Need remote codes for Toshiba TV/DVD combo Model sd-p4000
code list for philips remote for my toshiba TV
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
