20 Most Recent Toshiba 23HLV84 23 in. TV/DVD Combo Questions & Answers
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_12_2012_5_43_23_pm.jpg6_12_2012_5_43_42_pm.jpg
Toshiba 23HLV84... | Answered on Jun 12, 2012
On almost all these units the input or source (same thing) button will either be on the remote or the set or both.
Toshiba 23HLV84... | Answered on Apr 26, 2012
please confirm that model number posted here is correct or not
Toshiba 23HLV84... | Answered on Apr 10, 2012
No,tv internal DVD player are not on sale by itself as a seperate unit,only can buy it from the tv corporations themselves and it not cheap and have to have experience to putting it in into the tv internal tv itself.The tv internal DVD player now,could be the laser eye data reader have problems reading mp3 and mp4 files on the DVD disc,which are video files.Now tries to play more than one DVD movies dic,tries like to play like 5 to 6 original DVD movies.One disc don't play tries another DVD disc.Tries this might forcing the laser eye reader to read DVD dics again and than might fix it to read video files again.Or just buy an external DVD player hook it up to the tv and play DVD disc on to the tv video modes.DVD players external devices are really cheap these day,like can buy new one for $40.
Toshiba 23HLV84... | Answered on Mar 25, 2011
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck...
Toshiba 23HLV84... | Answered on Mar 07, 2011
If the power light is faint it indicates a high voltage problem in the set. The only course of action is take to a tv technician to have it assessed.
Toshiba 23HLV84... | Answered on Jan 09, 2011
I had a T.V that wouldn't allow a video eject if the top panel was locked maybe this is the same. To unlock the panel: Press and hold the VOL down
Toshiba 23HLV84... | Answered on Oct 04, 2010
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout in solving the problem, take care
Toshiba 23HLV84... | Answered on Sep 05, 2010
Some times there is a little hole that you can stick a straightened paper clip in.
Make sure the power is turned off first.
Toshiba 23HLV84... | Answered on Jul 25, 2010
Tip
Toshiba 23HLV84 Service Manual Download
Download Toshiba 23HLV84 LCD TV / DVD Service Manual
Have you misplaced your Toshiba 23HLV84 LCD TV / DVD Combo Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 23HLV84 LCD TV / DVD Combo Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
on May 03, 2010 | Toshiba 23HLV84 23 in. TV/DVD Combo
Absolutely you better bet it can, just hook up the cables to the front and select the input on your tv and you should be ok. For the internal DVD try running a cleaning disk you never know it could be just dirty.
Thanks if you like my advice and solutions please use the thumbs above to rate it and give me some feedback as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Toshiba 23HLV84... | Answered on Jan 30, 2010
let me know more about your problems for your assistance.
Toshiba 23HLV84... | Answered on Sep 02, 2009
Sir,I have problem with my laptop toshiba satellite a 135 s4677and this desk top know I using,the problem is other friend ti install new windows,after install if I try online or e mail some thing wrong becauseother person on my laptop, I check administrator that guys settibg share document,and to prouteck with Ansav ,Eset.I cant delete that program and software because the user password hidden.I think know he(BATAK guys Mrudt) online too mybe smile.thank you Sir hightechwarnet.laptopku sdh di lapkrim.tggu tgl,mainnya
Toshiba 23HLV84... | Answered on May 20, 2009
Toshiba 23HLV84 23 in. TV/DVD Combo Logo
Popular Tags
34 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
power light blinks red tv will not turn
  • Televison & Video
