20 Most Recent Toshiba 50H81 50" Rear Projection Television Questions & Answers
Toshiba 50H81 Sound but no picture
if you heard a pop that would be a capacitor unable to take the voltage, hopefully no other damage, you will need to identify the capacitors that have gone and replace the parts with the same number ie 40v 300uf 105c remember don't touch the 400v or 200v capacitors as they will still have power in them, discharge them by placing a metal object over the + and the - on the capacitor and then the board will be safe.it could also be the bulb has gone. you would need to check this as if the bulb has gone the tv will shut down. and flash but usually there is an led that flashes to tell you bulb failed.
5/28/2017 4:26:51 AM • Toshiba 50H81... • Answered on May 28, 2017
Toshiba 50h12-reception problem with ant 1 & 2
the tv has a built in decoder. if its scrambled it may be on the wrong setting. try resetting tv to factory settings and see if it sorts its self out. if not it may need the av board changing as it has a fault with the decoder chip.
5/23/2017 4:59:28 AM • Toshiba 50H81... • Answered on May 23, 2017
2answers
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
10/3/2016 2:41:12 AM • Toshiba 50H81... • Answered on Oct 03, 2016
How to fix red & blue lines to align, box 3,7.8 on 50H81?
Have to do convergence adjustments; provided the circuit part to convergence section works properly. Check it out first. If it works properly, do a convergence adjustment. Do it carefully. Before start to do it, read and understand all the steps have to do. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Details about this adjustments have given by one of the posts.
8/23/2014 1:13:12 PM • Toshiba 50H81... • Answered on Aug 23, 2014
0answers
POWER LIGHT BLINKS AND TV WILL NOT TURN ON TOSHIBA
The set is in protective shutdown, most likely cause is one of the fuses that protect the convergence circuit are blown.
Depending on your skill levels there are ways to determine if this is the case.
Let me know how much skill you have and I will be happy to assist you.
SD TECH
4/15/2014 12:00:13 PM • Toshiba 50H81... • Answered on Apr 15, 2014
0answers
Video input on the front and back don't work the only one that works is the HD its a toshiba tv model 50h81 can i fix this
if using a box unplug it and set from power and wait, then plug both up and let reboot to see if it helps--if a real problem in the set the cost to repair and the parts that may not even be available end the life of this set..
4/17/2012 2:01:39 PM • Toshiba 50H81... • Answered on Apr 17, 2012
Toshiba 50H81 very dark, blurry picture on all inputs.
check if the problem looks zig zag looking or it its not present in the PIP window. If so this may be an issue with the hypermodule - you can google TV repair Kits to find parts.
3/28/2012 5:02:50 AM • Toshiba 50H81... • Answered on Mar 28, 2012
Sound issues with picture turning off
you have a defective audio amplifier IC and must be replaced, likely cause is the shorting out of the speaker terminals, on the main board you will find a IC mounted vertical attached to a heat sink, flowing the speaker trace from the speaker connector may help to locate this IC, once you have found it you can obtain the part number from it and contact a local electronic pars supplier for a replacement, after you have the replacement and it is installed make cretin that there are no short circuits are in your speaker connections external and internal with an ohm meter. also you should check the speaker impedance is within tolerances of the tv speaker output impedance.
1/10/2012 3:20:41 AM • Toshiba 50H81... • Answered on Jan 10, 2012
2answers
Needs a slight realignment on the red bulb
The colors R,G,B out of alignment does not matter how much,any millimeters.The tv are having a convergence problems and will get worse.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be change to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
10/25/2011 3:47:02 AM • Toshiba 50H81... • Answered on Oct 25, 2011
Do i need hd cables for an hdtv?
If you want to watch some content in HD you will either need to connect your TV to the computer using a VGA or DVI cable, or connect using HDMI(picture + sound transfer) cable to the computer/DVD... You can connect your TV also using Cinch or Scart cables but you will not have HD resolution. Hope this helps!
10/11/2011 4:55:34 PM • Toshiba 50H81... • Answered on Oct 11, 2011
Picture is only clear on color steam 2 and shacky
Possible that the input logic selector is faulty as there can be a digital gate failure.This can cause the input to be scrambled and so there is loss of sync. which can result in the poor picture. So it is important to trace the input, check using a signal feed to find the switching fault.It can also be related to a fault in the video board but the fault points to this section as the video signal is clear otherwise.
9/27/2011 9:58:14 AM • Toshiba 50H81... • Answered on Sep 27, 2011
4answers
Just replaced Hyper Module. After installing,no
IT SOUNDS LIKE THE MAIN PROCESSOR IS LOCKED UP AND IF YOU UNPLUG THE SET FROM THE WALL, FOR 40mIn, IT SHOULD GO BACK TO NORMAL.
9/6/2011 12:14:17 AM • Toshiba 50H81... • Answered on Sep 06, 2011
Hello friends, I have a 42hm66.
Symptom shows problem with DMD chip that generates an image, DMD chip replacement is job of qualified tv repairman and mostly DMD board or complete light engine gets replace in Toshiba DLP TVs.
Hope this will help.
Thanks.
5/13/2011 11:51:18 PM • Toshiba 50H81... • Answered on May 13, 2011
2answers
I have a 52" toshiba
You are going to see this same answer for a lot of problems that are temperature related. It is a good first step.
I need to assume you are a DIY and have some electrical experience. If you aren't comfortable taking apart on of these TV's then you should call an expert. If you are comfortable, then read on.
It has been my experience with older rear projectors that the solder joints on the main board become cracked over time. If you have a set that shuts down or stops working properly after warming up, you might be able to check the board for bad joints.
Always be careful when working on these old beasts. I would always unplug them and let them sit over night to discharge a bit before opening them up. The picture tubes still hold a charge so be careful.
Cold solder joints or cracked ones can be seen with really good lighting. Look for a half moon shape on the solder joint, epically on the large transistors near the heat sinks. Be careful not to cause solder bridges when you are touching up the solder joints.
Hope this helps.
5/1/2011 9:05:09 PM • Toshiba 50H81... • Answered on May 01, 2011
Toshiba 50H81 50" Rear Projection Television Logo
Popular Tags
195 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
friends 42hm66
  • Televison & Video
