The vertical height and lenearity confuguration to your tV has been changed. Now vertical height is more than normal. To adjust this, you have to enter the service mode option window. It is an entirely different window, than its Menu windows. Visit this site for more details.Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search.It is an electronic equipments service help site.All details you want are there.Note the position of hyphen in between words in site name, when you type it in.The site will appear as it is in web; subtitled as electronics equipments' repair help. Entering into service mode to many brand of TVs are described here. Pull up older posts there. Sometimes, advertaisements at the side and bottom of each post might help you.
It is a video problem. If it is a laptop then you might have to replace motherboard. If it is a desktop and if it is not integrated then it can be either motherboard or video card .
2 Convergence ICS and some or all the resistors are dead.Know how to solders?Buy a covergence kit at websites Trepair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
when its hard to read words its usually the sharpness which make the t.v.'s look either blurry or sharp or right in between. you can fix this by adjusting it thru your tv's menu either on the tv or your remote, look under the picture tab in the menu and there should be a sharpness adjuster there. adjust as needed
The convergence Ics are needing replacement. If you post the model number of your set I can post where you vcan get the repair kit for your model which has the parts and instructions on CD
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge. if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
