20 Most Recent
Samsung DynaFlat TX-P3064W 30" TV Questions & Answers
No picture, beeping sound.
it is due to your VIF OR TUNER section has stopped working due to no supply or some parts gone defective.
some times it is due to signal absent from the source from you are getting.
good luck.
Gray picture for all RGB inputs
Check the connections. If connections to RGB has conected wrong, this type of fault will occur. Follow the color codes of wire ends both at tV and DVD.
My 2004
Could be a bad
flyback giving its making some noise, I would not be turning this on anymore :(
If its worth $95 bucks to you I would take it to the local tv repair shop to get a new
flyback put in.
thanks i hope this information does help please do click the accept button to credit me for my efforts. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Cant use TV as Computer display
If you can disable the blue screen via the tv menu you might see something happening behind that blue ,you might be able to figure it out from there, also try to connect as directly as possible (tv/computer) even if you have to physically move one or the other, that way you can eliminate possible problems. good luck
Set will no longer turn on.
This is an older tv. Generally, yes the power supply would not be an issue but possibly it is, any part can fail and the power supply does make a low noise. Probably, the High Voltage board is the issue though and should be tested. I am going to let you know right now that if you want to repair it, it just won't be worth it especially if you aren't electronically inclined since shops will charge $50 just to look at it. A new LCD tv would probably be in your interests, especially with how electronics are always getting cheaper and cheaper.
Benjamin
Picture is Psychodelic....
I HAVE A SAMSUNG HD TV MODEL TX-P3064W AND I TURN IT ON AND GOT ALL OF THE COLORS IN PSYCHODELIC MODE. I NEED TO KNOW IF THIS IS AN EASY AND CHEAP FIX?
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
My tv cant turn on
make sure the c5299 s not shorted again. and if it is not i suspect your flyback transformer is bad . check for cold solder joints on voltage regulator and board.
1 flyback transformer
2 voltage reulators
places to get parts
www.partstore.com
www.samsung .com
Give Them the model number they can cross it to part
GOOD LUCK DOCTOR VIDEO
becareful it is highvoltage
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
TV doesn't turn on
Washing TV where in a bathtub.. Oh man Tvs cant be washed in a sink or a bathtub.??
No Picture
VERY common on this set, in fact we did three just last month...
Replace Fjl6920 - subs to 2sc5144 or NTE2661
Replace flyback Samsung P/N# AA26-00225A
Bill
Color Temp Change
you have a picture tube problem, or bad capacitors in the screen circuit. I'm afraid not a job for the end user. A repair shop should be able to assist you in this repair. good Luck
Samsung television black shadow fix?
bro you should take it to the repairer,No other options you have. it can't be fixed by doing anything accept changing it's screen or repairing it, if it's possible
4/23/2024 1:56:46 AM •
Samsung...
Answered
2 days ago
