20 Most Recent
Sylvania 6432TE 32" TV Questions & Answers
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Why does OSD menu keep popping up?
Try a reset to this set, and check. If it do not help you, check and replace its main system control memory IC. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Type in this key phrase
" my service table today "
in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Game mode not showing any picture
If you get a picture on regular TV then the tube is fine. If you get audio on game mode try changing the red or white plug to the yellow plug and see if your picture is there. If so you have a bad yellow cord. If not then the solder connection on the board inside TV is bad. If you also have no audio in game mode then the whole board is bad.
I need a code for a sylvania flat screen tv
Hello
Three digit universal remote codes for Sylvania TV are:
004/008/009/062/068/069/074/075/076/077/133/161&163
Four digit codes are:
0062/0004/0009/0135/0189/0183/0227/0456/0008/0068/0075/0141&0161
OK.
Im want to use my
I am sorry, you will need the original remote or a remote that is similar.
You can check out 1800remotes.com and see if they chan help.
Thanks
asnowman
32 inch sylvania tv
To fix the problem:
Please help!
The code for the Sylvania 6432te 32" TV with the "Innovage products- Jumbo universal remote" is 189. you push and hold down the code search button, when the light starts to flash, hit tv, then the number "189". Finally, push the power button off on the remote control. if the tv turns off, then it worked. :)
I have an old Sylvania tv and it won't turn on
Here are some troubleshooting tips to try. However, as it is an older set, if these tips fail, the cost of a repair at a shop might exceed the value of the TV. In short, a new TV may be in the works. Cross your fingers. One of these tips may work.
Let's troubleshoot the issue and try to get it working:
If you are using a remote, check the batteries in it. If you are using several remotes with it, try the alternative remote. Sometimes there is a glitch affecting the remote for a Roku where it won't turn on the TV other than a powered black screen and you have to use the other remote to turn it off and back on and then the Roku screen pops up. I have not sorted out why.
Check Power Cord and Connections:
First, ensure that the power cord is securely plugged into both the TV and the electrical outlet.
If you suspect a faulty power cord, consider trying a different one.
Reset the TV:
While most Sylvania TVs don't have a dedicated reset button, you can perform a manual reset:
Unplug the TV's AC adapter from the electrical socket.
Press and hold the Power button on the TV for 20 seconds.
Plug the AC adapter back in and turn on the TV.
Check Audio/Video Cables:
Inspect the audio/video cables connecting your TV to the satellite or cable receiver.
Ensure that the color-coded prongs match their respective connecting points.
Correct any mismatches (e.g., white cable into a red port) by reorganizing the prongs.
Inspect Coaxial Cable:
Look for the coaxial cable on the rear side of the receiver, attached to the port labeled as ANT IN.
Confirm that the connection is firm; a loose coaxial connection can cause display issues.
Tighten the cable by pinching the silver band on the end and rotating it clockwise until secure.
Check for Interference:
If distortion continues on the TV screen, consider nearby interference.
Power-hungry appliances can cause electronic interference, affecting display quality.
Visit a Repair Shop:
If the above steps don't resolve the issue, you may need professional help.
Some technical faults, such as a blown fuse or faulty capacitor, require expertise in dismantling and soldering.
If uncomfortable with such tasks, consider visiting a repair shop
2/3/2024 6:17:20 AM •
Sylvania...
Answered
on Feb 03, 2024
I have a 37in limited edition Sylvania TV I have tried every code on my Phillips universal remote none work. Is there a specific code.
- Auto Code Search:
- Turn on your Sylvania TV.
- Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
- Press the "TV" button on the remote to set it to control the TV.
- Press the "Power" button repeatedly until the TV turns off.
- Press the "OK" or "Enter" button to save the code.
- Manual Code Entry:
- Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
- Press and hold the "Code Search" button on the remote until the indicator light stays on.
- Enter the code using the number buttons on the remote.
- Test if the remote now controls your TV. If not, repeat the process with a different code.
- Try Common Codes:
- Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
1/9/2024 10:32:14 PM •
Sylvania...
Answered
on Jan 09, 2024
