I appears that some of the mirrors are not working, I see small lights (looks like stars in the sky) at different spots on the screen, some blink and some are steady First there was one, then three and now there are about ten. some disappear and then return. Any ideas?
Mongo
SOURCE: Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
SOURCE: My analogue tv signal keeps dropping out for days at a time
do the isolation type, start by connecting one tv, if it works, connect another one and so on.
what is happening is that all the tvs are connected in parallel if one line shots then all lines goes off. because of common output.
okay
SOURCE: no picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
SOURCE: Black spots appeared on 17" LCD Monitor-SyncMaster740N
It looks like you're developing dead pixels on your LCD screen. Short from buying a new screen to fix this problem, there are a few methods that may work. Here is the best guide that describe a few ways of unsticking those pixels.
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
my personal recommendation for a software fix (try it before doing anything physical to your LCD) is UndeadPixel.
http://download.cnet.com/UndeadPixel/3000-2094_4-10671596.html
SOURCE: Very slow to turn on and has small light spots all over screen
The first thing to look for are swollen capacitors on the power board.replace them if so.
