It will not shutdown
Remove the battery and unplug it from the wall. Try holding down the power button for about 8 seconds it should shut down. Just a suggestion! When you shut down your laptop make sure that your shutting down properly at the start button select shut down. If all else fails and this does not work.
You may want to have the power button checked out or the board. Or clean files out and start up programs add-ware or spy-ware may be preventing you from shutting down as well. This is also a common issue that causes very slow shutdowns on any computer system packed up junk having to close out. John
