20 Most Recent Dell Latitude E5500 Laptop Questions & Answers
Hello, how long does it take to shut down? If you a chance to check and have a diagnosis (I attached a link) it would be much easier to fix it; The other option would be to visit the dell store or a reliable mechanic to make some measurements of the different elements. I exhort you to watch a video so you can have an idea and know the proportions of this problem and if you have no knowledge of electronics it's better that you don't do it, please. https://www.dell.com/support/home/us/en/19/quicktest
Dell Latitude... | Answered on May 11, 2019
NEED YOUR SERVICE TAG NUMBER
CHECK OUT THIS WEBSITE...
http://forum.gsmhosting.com/vbb/f88/bios-password-dell-latitude-e5500-1139381/
Dell Latitude... | Answered on May 31, 2018
reinstall XP or upgrade to Windows7
Dell Latitude... | Answered on Oct 30, 2017
No reformatting will help . Unplug LED screen vga from board and see if laptop will work on external screen . Could be magnet switch .
Dell Latitude... | Answered on Sep 16, 2016
Go to the start menu and click where it says run or type in right above the start button in the white field and type ncpa.cpl then push enter. Where it says wireless network, right click on it then click enable. If needed, right click again and view wireless networks or Connect/Disconnect then connect to the wireless network. Also there could be a tiny switch on the right side of the computer where you turn on the computer, there might be a button to click to turn it blue. Hope this helps
Dell Latitude... | Answered on Jan 27, 2016
You must be logged in as an administrator and not a normal user to change password.
Dell Latitude... | Answered on Dec 13, 2015
Did you get a recovery disk that the first buyer should have made? If not, you may need to borrow the exact same one from someone and use your key which you should have gotten when you bought it and reload the system. That's only if the seller can't or won't tell you what his is.
bad battery, or battery connections
Dell Latitude... | Answered on Nov 19, 2015
Hello, Either your charger isn't working or the battery you just got is bad, take it back and exchange, if that doesn't work then your charger isn't charging.
Dell Latitude... | Answered on Nov 02, 2015
ensure that the correct keyboard is set, the region and language in control panel should match your region and language.
If the settings are correct ensure that there is no mistake in the keyboard selection in your system tray, (the bottom right corner of your screen.)
If all is as it should be fit a n external keyboard and see if that works okay...if it does you need a new keyboard.
Check Ebay for these, they are cheap and plentiful on that website usually.
Dell Latitude... | Answered on Aug 07, 2015
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Dell Latitude... | Answered on Jul 24, 2015
what is the program? do not save any changes you have made if you are rederring to a document...close the app without saving, it should revert to the version available when you last saved
Dell Latitude... | Answered on Jun 17, 2015
Usually next to the Ctrl button on the lower part of the keyboard.
Dell Latitude... | Answered on Jun 07, 2015
Hi Mar Mar,
As far as I know once the you forgot your BIOS password no more options to get it anymore. You may also wanted to talk to Dell Tech Support 1-877-542-3355 in order for them to check if they can still do something about it. Worse scenario would be replacing your MOBO.
Dell Latitude... | Answered on Mar 07, 2015
Remove the CMOS battery for 30minutes.. Fit a new one and try again.
Dell Latitude... | Answered on Mar 01, 2015
The BIOS-password exists for _your_ protection; if a thief is in possession of your computer, the password prevents the thief from using the stolen computer.
As the owner of the computer, find the original sales-receipt, to prove ownership, and telephone Dell, to get assistance from Dell to bypass that password.
Have you tried safe mode? If it works in safe mode it could be a corrupt video driver.
Dell Latitude... | Answered on Feb 06, 2015
Dell Latitude E5500 Laptop Logo
212 questions posted
Clive
Clive
Alun Cox
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
daughters dell latitude e5500 charge
  • Computers & Internet
