I'm helping my parents install this printer to their travel laptop, which is a netbook. Installation went fine, just plugged in the printer and windows installed it automatically. When I try printing, however, the printer only prints a blank page. This happened both when I tried to print a wordpad file with only the text 'test', and when trying to print out a color photo. There are no warning lights flashing on the computer, nothing to indicate that ink is low or a mechanical failure of some time. The computer feeds the paper in, and makes printing noises, but the page comes out blank.
SOURCE: 5610xi won't work (at all) with Vista 64bit
hi,
you can try this workaround.. most of the printing issues can be solve by doing the following steps.:
1. download the Printing diagnostic utility
2. install it, and run it.
3. when its open, click on DIAGNOS, it will give you several errors why you cant print.
4. after doing that step, click on FIX. it will automatically fix the issue.
5. after that, it will give you all green checkmarks. then try to print something.
below is the link where you can download the file "printing diagnostic utility"
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=mp-56143-2&jumpid=reg_R1002_USEN
SOURCE: trying to install HP J4680 AIO printer and installation fails at
trying to installhp j4680aio printer and installation fails
SOURCE: HP DeskJet 5150 , ink problem :S
replace the cariridge because when you refill the sensor gets triggered and the cartride is unusable.
SOURCE: Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
SOURCE: My HP Photosmart C3180 doesn't want to print. It
You might need to reinstall th driver.
You can try this link to download the drver.
Just choose the appropriate operating system.
