Title: No startup but CPU Fan vibrates Product: Compaq Presario S5000NX PC Desktop with XP Pro Details: After shut-down, start button causes CPU fan to try to start and at times will go full blast for a second then returns to vibrate. Full blast does not last long enough for proper boot. Intermittent problem in that on one occasion machine booted and worked properly after fan worked went full blast. But when placed in sleep-mode and resumed problem on wake-up. Drive lights all work. Power supply light OK.. When fan vibrates, there is a ticking noise as if it is trying to start. Normal startup for this machine is for CPU fan to come on full blast for maybe 10-sec' boot occurs, then fan slows to a quiet running speed. "Full blast" means a high speed with lots of fan noise.
SOURCE: loud Dell desktop
Any fan that is making noise you would need to replace. There is also never a need to use alcohol to clean a fan. Some computer air or a light wipe down will do just fine.
If you have any other questions let me know.
Thanks,
Lee
SOURCE: EMACHINE T6542
I don't see how removing the battery would help but tried for the same problem and it did in fact do nothing.
The fan races but the system never makes it to the Bios and never displays anything on the monitor. I suspect a chip is fried on the MoBo.
Maxum52, please post the solution if you found one.
SOURCE: Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
SOURCE: can't reboot Compaq/Presario desktop, (power supply is working)
first can you try to disconnect power and IDE cable cd-rom,cd-rw,dvd-rw and floopy disk then see can boot up no stop in the screen says loading boot menu... and stop right there.make sure HDD is conected
second try disconect you HDD only other can connected to see can boot up no stop in the screen says loading boot menu... and stop right there
if solution one is ok means you dvd go problem.if second solution ok meand you HDD faulty.can you try put you RAM in diferrent slot
Mea Culpa - I should have noted in the question that I did replace the fan and I also removed and cleaned the heatsink and put new compound on the CPU. Heat is not a problem, everything is cool, even that one time when it started and booted properly. It's a real mystery. Thanks for your kind attention.
