Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
Posted on Nov 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony 35 inch flat screen and wide body
Picture is pink
Jerry Greenberg
Level 3:
Genius:
  • Sony Master 1,691 Answers
  • Posted on Nov 25, 2008
Jerry Greenberg
Sony Master
Level 3:
Genius:
Answers
1691
Questions
Helped
736190
Points
3767
In this model this is usually caused by a failure in the picture tube. Sometimes there can be a fault on the CRT driver circuit board or in the AKG (Automatic Cathode Gain) circuit area.
This type of fault condition is not usually feasible to service in these TV sets.
Jerry G.
1helpful
46 inch sony picture too wide cant adjust with remote
If the Dish remote won't change the picture size when you use the "Format" button (either bottom left on remote or the "page up", "page down" buttons), then you will need to try the Sony remote. If the Sony remote doesn't have a "picture size" or "format" button, then enter the Sony User Menu and look in "Set up" for "Picture Size" "Format" or the like.
Hope this helps!
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
1helpful
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
1helpful
Picture distortion
check the settings on the dvd as if you set the dvd to 4:3 format for instance, the picture will be "squashed" to a letter box format and when you play on wide screen it will become "morphed" and mishaped. also if the tv is set to wide all the time, then this will cause a stretching effect. set the tv to auto picture size or "smart" as it is on sony's, with auto 16:9 on.
Changed Lamp on KDF50E2010 now have pink band
Is this on all inputs.If so optical block could be bad.
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
[email protected]
Horizontal streak in screen
Does it only show up on Cable or does it shows on all Dvd, Cable, Sat, etc ?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
