Please, I am desperate to solve this air conditioning problem. I live in a two-story house. Downstairs, the AC seems to work fine and the air flow coming out of the vents feels cold and strong. However, on the second floor, the air flow is very weak from the vents, and as a result it's always hot up there. It's been very hot here in Oklahoma for the last couple of days. During the day with the thermostat at 68 degrees, the thermometer on the thermostat never falls below 84. The AC runs all day long and the power bill is way too high. It's bearable at night but not much cooler. The upstairs is at least 10-12 degrees hotter or more than the lower level. I can feel cold air coming out of the upstairs ducts, but it's just not a strong flow of air like downstairs. We've had AC repairmen visits several times, and the only thing they accomplish is leaving me with a huge bill and no better temperature upstairs. There is no ice on the pipes that I can see. What can I do to improve the air flow? I'd appreciate any and all suggestions you might have.
SOURCE: No air flow upstairs
Cold air is denser than hot air, so is harder to move. All vents have some mechanism to regulate flow, so close all of the downstairs vents. Check to see if your furnace fan motor has more than one speed, & set it on maximum. Keeping the fan on all the time will help as well. If all else fails, you may need a more powerful fan motor.
SOURCE: A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
