20 Most Recent Goodman CKL60AR60 Air Conditioner Questions & Answers
My Goodman Furnace model number GDH80703AXAC keeps tripping the breaker
fan motor or capacitor.
8/14/2015 12:16:51 PM • Goodman... • Answered on Aug 14, 2015
Goodman pgb030075-1 low airflow inside house can i
the installer selected a fan speed that would be a compromise between air necessary for heat and cool. check what color wire he used coming off fan motor. black is usually high speed.
8/14/2015 11:51:04 AM • Goodman... • Answered on Aug 14, 2015
NO POWER TO MY LOW VOLTAGE THEMOSTAT
rarely is the blower motor fused that might be a 2.5 amp fuse read across the fuse if you have 24 volts it is bad.
8/12/2015 8:34:24 PM • Goodman... • Answered on Aug 12, 2015
What is age of the goodman ck60-1c air condintioner?
need serial number for age.
8/12/2015 11:45:52 AM • Goodman... • Answered on Aug 12, 2015
Outside united is blown the small 3 amp fuse in furance
shorted coil in outside contactor most likely.
8/12/2015 11:38:05 AM • Goodman... • Answered on Aug 12, 2015
Ck60 1c
blower relay.
8/12/2015 11:27:16 AM • Goodman... • Answered on Aug 12, 2015
How mant tons is a cLJ42
3and 1/2 ton
8/12/2015 11:19:30 AM • Goodman... • Answered on Aug 12, 2015
Outside ac unit working inside not
fan relay, capacitor, or fan motor.
8/12/2015 10:50:00 AM • Goodman... • Answered on Aug 12, 2015
Outdoor unit compressor is not working model #
bad contactor or compressor
8/11/2015 10:28:29 AM • Goodman... • Answered on Aug 11, 2015
How much r-22 will a goodman 5 tons ac hold
the data plate on unit will give amount.
8/9/2015 10:26:44 PM • Goodman... • Answered on Aug 09, 2015
I replaced the 60 amp breaker cause it kept tripping now the breaker doesn't trip anymore but the outside unit won't come on
if you were tripping a 60 amp breaker i would replace contactor that can burn contacts quick.
8/9/2015 7:43:07 AM • Goodman... • Answered on Aug 09, 2015
Can a bad txv cause a ac unit to freeze
yes. if the power head goes bad it could feed excesive amount of refrigerant.
7/4/2015 6:09:14 PM • Goodman... • Answered on Jul 04, 2015
Goodman heatpump/acbreaker gets hot
heat is directly related to amp draw. coud be a breaker going bad or the buss it plugs on corroded i would check breaker by taking it out and examing the part plugging into buss. also possible excessive amp draw of unit.
7/4/2015 6:07:08 PM • Goodman... • Answered on Jul 04, 2015
3answers
Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
11/8/2014 5:08:57 PM • Goodman... • Answered on Nov 08, 2014
Unit not cooling
Low on refrigerant charge! Low side line should be cold like a beer can at the inlet of the compressor with some sweat beads around it. 55deg. The discharge should be around 125deg just hot enough you cant hold it long!
11/8/2014 4:46:29 AM • Goodman... • Answered on Nov 08, 2014
I need to find a parts dealer for goodman heat pumps.
let me know where you live and I'll find you a dealer
10/28/2014 8:23:34 PM • Goodman... • Answered on Oct 28, 2014
2answers
I have a 5 ton
Heat pumps require a reversing valve for heat operation on the outdoor section, a control signal to a "O" terminal or orange wire is required for heating and cooling depending on the thermostat and out door unit requirements. The thermostat also has to be heat pump type for the system to operate heat for electric system with heat strip, two stage electric heating.
9/25/2014 12:39:51 AM • Goodman... • Answered on Sep 25, 2014
Need capacitor values for large cap on outside unit
It is written on the cap in uF for example 45uF.
7/16/2014 1:08:15 AM • Goodman... • Answered on Jul 16, 2014
How do i wire a run capacitor 3 terminals to a 2 terminal run capacitor?
just hook the brown wire to one terminal of your new capacitor and brown/white to the other dont worry about the rest if it leave the wire off the f of the old three wire capacitor you now have two two wire capacitors one feeds compressor the other feeds fan
5/16/2014 7:40:00 AM • Goodman... • Answered on May 16, 2014
What size capacitor for a cpke42-1b
You will need to call Goodman. I rely can't imaggin how the compressor can start with out a start run capacitor.
5/15/2014 5:41:45 PM • Goodman... • Answered on May 15, 2014
Goodman CKL60AR60 Air Conditioner Logo
153 questions posted
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Goodman Heating & Cooling
Most Popular Question
goodman model ck60 1c white rogers
  • Heating & Cooling
