Hi!!
It should be an access plate fasten by a couple of screws right below the power cord, remove them and fix the cord's terminals/contacts or the cord itself.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Remove the back plate where the cord attaches to the iron... there are 4 screws visible and another 2 screws hidden under the two rubber feet...These are joined together by a rubber strip and can be removed by prying up and out with a small pry.... once the cover is removed you will see where to take the old cord off and replace it with a new one..
