20 Most Recent
Euro-Pro Steam Generator EP8001 Iron Questions & Answers
Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Hi i have an edbs920
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
What can be done about leaking steam?
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
Euro Pro Steam Generator EP8001 Iron - manual needed
Contacted Shark customer service and they emailed one. My product was the EP 8000 which is no longer produced. Sent the revised manual that is only a bit different for the EP 8001. Call them, they are very nice.
