20 Most Recent
Euro-Pro Shark Rapido Electronic Iron - White/Gray Questions & Answers
Shark Iron just quite working i have had it about 8 months and it has been good
given the potential danger, and relative low expense, would you just consider trashing this and buying a new one? I don't intend to sound short or sarcastic....it's just with the burning smell I would prefer you either return it for refund, call the manufacturer or trash it for a different iron.Looking at epinions.com there is a comperable iron for around $40-$50 with 24 reviews and 3.5 stars out of 5.http://www.epinions.com/prices/pr-Black_Decker_D2030_Iron
Hoo.comall my lights flash when
the electrical cord of your iron maybe broken and makes contact now and again. thats the reason the light flashes when it makes contact..check it properly.good luck.
How do you open the back plate to access the power connection. On a shark model G1568 iron??
We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
